Correct.Thank you for the insight about setting the driving pins to match the signal pins from the sensor. I wouldn't have thought to do that. I'm assuming it's to help reduce power consumption and to prevent any damage to the devices?
One subtle cause of current drain is when one (or more) output pins end up powering a sensor or other device through an input-pin protection diode.
