Low power audio amp
Discussion in 'The Projects Forum' started by tinusw7, Dec 21, 2011.
  1. tinusw7
    Dec 21, 2011
    Hi
    I have built an audio player based on the ATTiny85 and will run it with battery power. As the microcontroller does not deliver enough power for the speaker, I need an amplifier for the audio signal. When the player is not playing a song, it should consume almost no energy in order to have a long battery life. The microcontroller in sleep mode is no problem, but the amplifier quiet power consumption should be near 0 mA as well. The audio amplifier chips that I´ve found so far () have a quiet current of 4mA which is too high. Do you know a good low power audio amplifier solution? Thanks a lot for all advice.
    Regards
    Martin
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  3. jimkeith
    Oct 26, 2011
    539
    99
  4. crutschow
    Mar 14, 2008
    13,494
    3,373
    With the Maxim class D amp bertus suggested you just need to disable it when the μC is in the sleep mode. When disabled the amp only draws a few microamps.
  5. tinusw7
    Dec 21, 2011
    Thank you all for the info, will look closer to the Maxim chips (both of them).
    /Martin
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    Here is a TPA3125D2N from DigiKey
    $2.64 + cheap support components,Typical Circuit on page 1 of the datasheet
    0.39mA quiescent current in shutdown/sleep mode
    TypeClass D
    Output Type1-Channel (Mono) or 2-Channel (Stereo)
    Max Output Power x Channels @ Load36W x 1 @ 8 Ohm; 10W x 2 @ 8 Ohm
    Voltage - Supply10 V ~ 26 V
    FeaturesDepop, Mute, Short-Circuit and Thermal Protection, Shutdown
    Mounting TypeThrough Hole
    Supplier Device Package20-PDIP
  7. tinusw7
    Dec 21, 2011
    Thank you for the suggestion, looked good but then I realized that I forgot to say that the supply voltage is 3V, i.e. wont work with that one. Sorry for that but thanks anyway!
  8. thatoneguy
    Feb 19, 2009
    6,357
    718
    Please specify voltage when asking. :)
    No Through hole, but large surface mount is available
    TDA749313
    TypeClass D
    Output Type2-Channel
    Max Output Power x Channels @ Load3W x 2 @ 4 Ohm
    Voltage - Supply3 V ~ 5.5 V
    FeaturesDifferential Inputs, Short-Circuit and Thermal Protection, Shutdown
    Mounting TypeSurface Mount
    Supplier Device Package24-HTSSOP
    tinusw7 likes this.
  9. tinusw7
    Dec 21, 2011
    Yes, will remember that for the future :)
    Thank you, this one looks really good, only 1uA standby current! I'll order this one and do some tests.
    /Martin
  10. skycarl
    Nov 16, 2011
    That really is a nice amplifier. Kind of wants to make you put a circuit together just to
    use it.
  11. Audioguru
    Dec 20, 2007
    9,411
    896
    The TDA7493 IC is rated only when its supply is 5V then its output power is 2.2W into 4 ohms at 1% distortion. It might barely have any output with a 3V supply and might have no output when the battery drops below 3V.
