Hypatia's Protege
- Joined Mar 1, 2015
- 3,228
And the 'best' part of it is -- you can 'cover' the MF, HF, and, likely, most of the VHF band with a single oscillator! Golly! Golly!!!I have used in AM band and in SW bands too.
Connected and working as intended, there will be output (in 'half-power' decrements) every other 1 MHz on up the bands! -- If that now qualifies as 'sound design' that's truly sad!The issue here is user error (errors), not the conceptual soundness of this design.
Sufficient instrument bandwidth and properly terminated probes will help that! --- Even 100 MHz SXOs beat their transition time specs!As to "square wave", you should put your scope on the output and you may be surprised at how "unsquare" wave they are.
I don't understand why people are coming to the defense of this appalling circuit?! -- Operated at, say, 100kHz, and promoted as a 'signal injector', it would represent a passable beginner project --- But describing a modulated noise source as a communications device is sending the wrong message to both the nubes and their nearby neighbors alike!
With genuine respect
HP
