Low pass filter
Discussion in 'The Projects Forum' started by noingwhat, Sep 9, 2010.
  1. noingwhat
    Jul 23, 2010
    61
    I want to create 3 different low pass filters and I want to know how to calculate the values of the capacitor and resistor I need to use. I want to build a passive filter for each, and I want to make one 100Hz, one 500Hz, and one 1KHz. Here is the kind of circuit I would like to try to use:
    What kind of formula can I use to calculate the capacitor and resistor's values?
  2. marshallf3
    Jul 26, 2010
    2,358
    201
    http://tinyurl.com/37t2g5g
  3. noingwhat
    Jul 23, 2010
    61
    lol, that's kinda cool, but I had already tried searching for low pass filter calculator, and I didn't find anything useful. I'll try this though.
    btw, what does the RC stand for?
  4. noingwhat
    Jul 23, 2010
    61
    Well now, that is embarrassing. Thank you very much Marshall, that helped quite a bit. Once last question, how do I know what kind of wattage I need for the resistor?
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    R is for resistor and C is for capacitor.
    hgmjr
  6. noingwhat
    Jul 23, 2010
    61
    wow, i am such a noob... RC.. duh!
    Thank you.
  7. noingwhat
    Jul 23, 2010
    61
    One last question:
    Where do I connect the ground to? From what I understand, the capacitor is supposed to act like a variable resistor based on the frequency, but if it is just attached to ground, it seems like it would be doing no good, as it is an open circuit, so is there something I am missing somewhere, or do I just need to connect the capacitor to ground and it should all be fine?
  8. Kermit2
    Feb 5, 2010
    3,838
    961
    The capacitor acts like an open line for straight DC voltage levels. They pass AC voltage, and depending on the value of the cap will exhibit a higher or lower resistance to an AC voltage of any specific frequency.
    The 'ground' for AC signals is more of a 'common' line for the components. In DC circuits ground is usually, but not always, the negative side of the voltage supply. Most AC circuits will have a DC component somewhere in amongst the various components, so ground in that case will be the power supply negative(not always though)
  9. noingwhat
    Jul 23, 2010
    61
    Ahhh... so it is setup how I originally thought, the positive passes through the resistor into the speaker, and the negative comes out, while the capacitor is a bridge between the two. Great, thank you very much everyone!
  10. marshallf3
    Jul 26, 2010
    2,358
    201
    Like anything in Google (or any other search engine) it's a matter of figuring out the correct seach words. I've learned a lot of things I probably didn't need to know by using the wrong terms or spelling throughout the years and I mean some really bizarre stuff.
    My rule of thumb is - unless I'm looking for something that's rather complex in nature - if I don't get quite a few decent "on topic" hits within the first page or two I change my search terms.
  11. jhili
    Sep 19, 2010
    Dear all
    I am doing an exercise but I am stuck on this, maybe someone can help
    I have designed a constant K filter with a pi network where the load is 600ohms and the cut off freq is 15kHz, now i need some help to design the circuit response showing it as a Butterworth response.
    Found already the L =12.7mH and the C = 17.68nF then need some help.
    Thanks.
  12. Wendy
    Mar 24, 2008
    20,772
    2,540
    This is referred to as hijacking, and is strongly discouraged here at AAC. I noticed you started your own thread, which is the correct procedure. A thread, once started, belongs to the person who started it.
  13. Wendy
    Mar 24, 2008
    20,772
    2,540
    I didn't see anyone else say it, though it may have been in the URL. Where Xc = R, that is the filter frequency.
  14. marshallf3
    Jul 26, 2010
    2,358
    201
    Let us not forget, there are about 10 common lab projects going on right now and different people asking the exact same questions.
    Too bad we can't conslidate them into "Professor Orr's class project of lifting a door latch" or something like that.
    I think most of the info you seek is under electroic filter in wikipedia.
  15. noingwhat
    Jul 23, 2010
    61
    I will admit that about 3 of those are mine, but I am trying to teach myself, knowing nothing when I had started, and I don't want to just build circuits, I want to understand them, that is why I go into so much detail, so far that some people may consider overkill, but I want to be sure I am clear on everything.
