I'm pretty bad and inexperienced at this, so I get easily confused. I am trying to sketch and design a 1st order op-amp low-pass filter circuit that gives signal inversion. Does that mean just a simple op-amp low-pass filter with a NOT gate on the input/output?
This is my sketch for an op-amp low pass filter circuit.
I also want to perform an analysis to find the voltage transfer function. To do this, can I combine C1 and R2 in R2/(1+R2*SC1) where S = j*ω? Is the voltage transfer function the Vo/Vi from which I get the gain?
Thank you
Thank you
