Low pass Filter for Square wave
Discussion in 'The Projects Forum' started by balaji selva, Dec 2, 2013.
  1. balaji selva
    Nov 29, 2013
    20
    is there a low pass analog filter for square wave which does not cause ringing effect or conversion to sine wave.....
    or please say which is best filter for square wave...
    if so please give the circuit diagram of that filter...
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    Why do you want to filter the square wave?
  3. wayneh
    Sep 9, 2010
    12,374
    3,226
    I believe a low-pass filter for a square wave is simply a direct connection to ground.
  4. crutschow
    Mar 14, 2008
    13,475
    3,362
    What? :confused:
  5. MrChips
    Oct 2, 2009
    12,624
    3,451
    An inductor is a low pass filter.
  6. MrChips
    Oct 2, 2009
    12,624
    3,451
    For the op, you can create a low-pass filter using an inductor or a resistor and capacitor.
    But first, you have to say why you want to filter a square wave. What do you expect to happen?
  7. wayneh
    Sep 9, 2010
    12,374
    3,226
    Nevermind, it was me confusing voltage and frequency. Filtering out the higher voltage leaves you with zero volts. Presumably the OP is referring to frequency.
    Perhaps he wants to convert PWM to analog?
  8. LvW
    Jun 13, 2013
    674
    100
    I suppose you need something like a Bessel response?
    This lowpass filter is intended to preserve the squarewave form.
    ScottWang and #12 like this.
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The first concept that you must grasp, is what, exactly, makes up an ideal square wave?
    An ideal square wave is comprised of the fundamental frequency, plus ALL of the ODD harmonics of that fundamental frequency. Thus, an ideal square wave requires UNLIMITED bandwidth. Since unlimited bandwidth is not practical/possible to achieve in a real physical system, we have to settle for approximations of an ideal square wave.
    If you run an ideal square wave through a low-pass filter, it will no longer be a square wave.
    Have a look at the animations in the Wikipedia entry for Square_wave:
    http://en.wikipedia.org/wiki/Square_wave
  10. #12
    Nov 30, 2010
    16,665
    7,310
    So, basically, there is no such thing as a square wave with only low frequency components. If you want a useful answer, you will have to tell us, how low do you want to go and how distorted can you put up with?
  11. MrChips
    Oct 2, 2009
    12,624
    3,451
    And if you filter out all the high frequency components you are left with a sine wave.
