Low Pass Filter design......
Discussion in 'General Electronics Chat' started by pjshah72, Aug 13, 2013.
  1. pjshah72
    Dec 17, 2012
    24
    Hi All,
    I have attached circuit for Low Pass Filter at cut-off frequency 60Hz.
    My input is 240VAC, 60Hz for this filter. My goal is to block all AC signal at the output of the filter (means I am looking for DC.).
    Two questions: -
    (1.) If I use attached circuit, can I get DC as an output of this filter?
    (2.) What will happened to 240Vac voltage? Will voltage (240Vac) stay same after output of this filter? (If yes, how can make it to ground?)
    Thank you!!!!!!
      File size:
      14.1 KB
      106
      File size:
      53 KB
      67
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    1) No
    2) There will be some loss due to the resistance of the windings, but you will have a hard time making the output close to ground. At 60 Hz. the reactance of the inductor would have to be >> 38 Ohms, like say 3.8 KΩ
    In this case the output would be about 2.375 VAC. As you can see that is a small fraction of 240 volts but it is NOT GND.
    On the other hand if the reactance is .38Ω then the output will be 237.62 VAC assuming no IR loss in the inductor.
    Maximum power will be transferred to the load when the reactance is 38 Ohms and the voltage across the resistor will be 120 VAC. The power dissipation in the resistor will be 378.9 Watts.
    Personally I've never seen a resistor that could handle that kind of power, but you may have other sources.
    Are you trying to convert AC to DC without using a transformer? Oh foolish noob -- if so this thread may be locked.
    simo_x likes this.
  3. pjshah72
    Dec 17, 2012
    24
    What do you mean by this thread may be locked?
    Is it not proper place for this problem?
    Yes trying to block AC and in other words wanted to grounded incoming AC.
    Like a Capacitor can block DC. Can we have anything that can block AC?
  4. #12
    Nov 30, 2010
    16,655
    7,293
    You can reduce the amplitude of AC by quite a lot, but there is no DC in a wall outlet, so nothing useful will be left. The problem with this quest is that this website does not allow talk of plugging directly into the outlet and using that without some way to make it safer.
    pjshah72 likes this.
  5. pjshah72
    Dec 17, 2012
    24
    I understand that wall outlet doesn't have DC. I am just looking how to ground/zero AC. But as you said this is not allowed here so I don't know how to get help.
  6. wayneh
    Sep 9, 2010
    12,361
    3,220
    Unplug it.
    simo_x likes this.
  7. crutschow
    Mar 14, 2008
    13,462
    3,353
    If you block all AC, then what DC are you looking for? :confused: There is none.
  8. pjshah72
    Dec 17, 2012
    24
    that was my question, how to block all AC? (If it is possible.) I thought to use LPF and trying to make filter that gives me close to DC from AC. If i will not get anything, then it would be fine.
  9. crutschow
    Mar 14, 2008
    13,462
    3,353
    The mains voltage has a DC average of zero volts so that is what a filter will give. It's a pointless exercise. :rolleyes:
  10. pjshah72
    Dec 17, 2012
    24
    ok. I am not sure this is a proper question to ask or not!! But wanted to know answer so I am asking here:
    How can we differentiate AC voltage and DC Voltage for power supply? In other words, in real world, can we make single Input (AC or DC) power supply? Is there a circuit that can tell us whether it is AC or DC?
    Thank you!!!
  11. tubeguy
    Nov 3, 2012
    1,157
    197
    Are you in a part of the world where the local (mains?) supply voltage could be either AC or DC ?
  12. pjshah72
    Dec 17, 2012
    24
    Supply voltage is always separate. Either AC (Mains) or DC.
    I am just asking (if it is possible) can we make circuit that can take both (one at a time)?
    First question came in my mind is- in real world, is this kind of power supply exists?
  13. wayneh
    Sep 9, 2010
    12,361
    3,220
    You can block DC with a coupling capacitor that will pass AC. It's not really practical in a power supply but it provides an easy way to detect AC. If something comes through, there is at least some AC component. There is also such a thing a zero-crossing detector which might be relevant.
    But, you could just use a full wave bridge. It'll accept either source and reliably ensure that only (pulsing) DC is at the output.
  14. Papabravo
    Feb 24, 2006
    10,338
    1,850
    If you look at the derivative of the voltage output you can tell.
    for DC the derivative is 0
    for AC(sinewave) the derivative is a cosine wave.
  15. tubeguy
    Nov 3, 2012
    1,157
    197
    As mentioned, running the supply through a bridge rectifier will produce either pulsing DC or straight DC minus the diode drops. Then run the voltage into both low-pass and high pass filters. Indicators could be attached on these outputs.
    Is this on the right track ?
  16. #12
    Nov 30, 2010
    16,655
    7,293
    It works for me. I have used the FWB approach to make DC inputs "idiot proof". One diode will produce, "won't work" for a backwards polarity of DC input. Four diodes will simply correct the polarity. They will also rectify an AC input and deliver the polarity correctly. Whether the magnitude of the input voltage is correct is different aspect to consider.
  17. pjshah72
    Dec 17, 2012
    24
    That was I thought last night. How can we detect frequency? Because AC has 50 or 60 Hz frequency but DC has always zero frequency. once we can detect "zero frequency" vs "non-zero frequency", we can route two signals accordingly.
    I hope there is something that can detect zero and non-zero frequency.
    Thank you,
    pjshah
  18. pjshah72
    Dec 17, 2012
    24
    Is there a bridge rectifier that can take AC mains as an input and also DC (30V max for my application)?
  19. #12
    Nov 30, 2010
    16,655
    7,293
    Yes.
  20. pjshah72
    Dec 17, 2012
    24
    How did you calculate 2.375 VAC at 38ohm resistor?
