LOW PASS FILTER (Clipping in input sinewave)
Discussion in 'The Projects Forum' started by mokong, Nov 11, 2011.
  1. mokong
    Oct 14, 2011
    6
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Without seeing your circuit, I'll have to say you have a/some wrong part(s) somewhere.\
    I don't know how you expected to get a useful reply without your schematic diagram.
    Upload it using the "Go Advanced" and "Manage Attachments" buttons.
    .PNG format files are preferred.
  3. mokong
    Oct 14, 2011
    6
  4. Ron H
    Apr 14, 2005
    7,050
    657
    Your input swings above and below ground (0V). Your op amp outputs can't go below ground. You need to use a negative supply for Vee, or you need to bias the input signal up to Vcc/2 by capacitor-coupling the input signal into a voltage divider on the left end of R5.
    mokong likes this.
  5. crutschow
    Mar 14, 2008
    13,523
    3,392
    Ron H is correct. Obviously the op amp outputs can't go below ground if they don't have a negative supply.
    If you want to design and simulate active filters you might try the free FilterPro design program from TI, if you don't already have it.
    mokong likes this.
