Low pass filter a data file
Discussion in 'General Electronics Chat' started by paultwang, Apr 17, 2006.
  1. paultwang
    Mar 8, 2006
    80
    I have a data file of pressure measurements of an animal heart in the form of Pressure vs Time. However, the sensor picked up some mains line noise (60 Hz). How do I low-pass filter it?
    The data file is in the form of:
    time1 pressure1
    time2 pressure2
    time3 pressure3
    The interval is not the same. However, I can interpolate to fix it.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If your data files have enough continuity to run a FFT, then do that and drop out the values clustered around 60 Hz.
