Low pass and high pass filters (newbie questions)
Discussion in 'General Electronics Chat' started by NY10, Aug 2, 2010.
  1. NY10
    Jul 30, 2010
    47
    Hi, all
    I believe that high pass filter can be made by using low pass filters because low pass filter is the basic one.
    Can anyone explain how it can be done or accomplish ?
    Thanks.
  2. tom66
    May 9, 2009
    2,613
    214
    The only difference between high-pass and low-pass RC or LC filters is the order of the resistors/inductors and capacitors. Since they have physically different layouts, it is not possible to create one from another.
  3. kingdano
    Member
    Apr 14, 2010
    377
    19
    This is the correct answer.
    Simple passive and low order filters are created by arranging resistors (R), capacitors (C) and inductors (L) in various topologies.
    Adjusting the values will change the effective cut-off frequencies.
  4. Ghar
    Mar 8, 2010
    655
    73
    Keep in mind that in a first order RC LPF the low pass response is across the capacitor while the high pass response is across the resistor. If you really want to go through the trouble of taking outputs across both elements you can.
    Interchanging elements, like inductors for capacitors, will flip what the circuit does as well.
