Low Operating temp SPST Power Relay
Discussion in 'General Electronics Chat' started by akj375, Feb 2, 2012.
  1. akj375
    Dec 21, 2011
    10
    Hi All. I've been looking for a SPST (form A) power relay that can operate at low temperatures, i.e. at least down to -50 Celsius. The one I need would have a 5VDC coil and 15A contacts. I've found a few with these specs but none that are rated to that low a temperature. This will be used in the Canadian prairies in the winter so it needs to operate at painfully low temperatures. Any suggestions would be highly appreciated. Thank you.
  2. Lundwall_Paul
    Oct 18, 2011
    222
    19
    I would talk directly to Newark, Allied or Digi-Key. Ask about MIL-Spec temp ratings for relays they should be able to fix you right up.
  3. praondevou
    Jul 9, 2011
    2,936
    489
    http://search.digikey.com/ca/en/products/T9AS1D12-5/PB1014-ND/1095335
    http://search.digikey.com/ca/en/products/JTN1AS-PA-F-DC5V/255-2816-ND/648654
    Did you also had a look for "solid state" relays? Maybe an option, even though I didn't find one having a quick look at digikey.
  4. akj375
    Dec 21, 2011
    10
    Thanks all. I did contact Digi-Key and they got back to me today after I already posted this. They recommended the following parts in cases anyone else is interested.
    255-2380-ND
    255-2838-ND
    255-3455-ND
