I really need help to solve this problem as it is my teacher's question on final exam.
In application note AN-1192, the Bridged-Paralel circuit of four LM3886 circuits. And there, in the schematics, are four servo circuits, which are integrators of DC voltage. It is DC offset protection. Those circuits needs LOW-OFFSET OpAmps like LF412, AD712, OPA2134 etc.
But, when I made a ciruit od PCB, many times happended, that one of the OpAmp got destroyed, probably because of voltage-peak. Mostly it happened in inverting type of servo.
When I changed LF412 or AD712 for cheap TL082 with input offset 3 mV, no problem occured and they (TL082) were worked properly. But while I put back AD712 after some test, it was destroyed.
So why are those low-offset amps so sensitive? When I looked to datasheets, they look almost same inside.
Thank you for suggestions
