Low-fuss Firewire output for a project?
Discussion in 'The Projects Forum' started by darenw5, Sep 22, 2008.
  1. darenw5
    Thread Starter Active Member
    Feb 2, 2008
    45
    For one of my harebrained projects, i'd like to output audio and other signals as digital using firewire to send to a computer. What is a good, cheap, low-fuss way to provide firewire outputs given analog signals but not given a PhD in firewire implementation technology?
    (plan 'B' would be to buy an audio mixer like the alesis multimix, but that is bulky, more $$ than i want to spend, and has a lot of features i won't need)
  2. studiot
    Nov 9, 2007
    5,005
    515
    You need to consider what software you have that can read from the computer firewire port.
    A cheaper option might be to obtain a video capture box with a firewire output, but only use the audio part. They normally come with suitable software. They are also often abvailable on Ebay.
    Look at the Datavideo offering.
    www.datavideo.com
  3. scubasteve_911
    Dec 27, 2007
    1,202
    Your process should be to understand what bandwidth is necessary, then work from there. Do you absolutely need firewire? USB has been a lot easier for hobbiests to implement in the last few years, you should consider this.
    Steve
