I need control a VCO (IC 4046) so it need a LFO (low frequency oscillator), it must be sinusoidal, range about 0.1 to 1.0 Hz.
Could someone say where find it ? or, How design it ? ( better if use single +9V).
The sinusdoidal part is the hard one. If I read the data sheet correctly the on board VCO will do the freq just fine. I've put some work into this, you can convert the square wave to a triangle wave, and then to a sine wave with an op amp intigrator.
It is for a chorus circuit, it use a BBD (MN2008) which use a external clock, I need sweep the clock slowly. For chorus the sweep must be sinusoidal (i.e, for flanger effects it must be triangular).
