Low Frequency Amplifier
Discussion in 'The Projects Forum' started by thetallstewy, Oct 30, 2009.
  1. thetallstewy
    Oct 30, 2009
    7
    Alright, we are a senior design group building a low frequency ultrasound reciever system. We need to amplifiy the signal from the transducers.
    So we need a two channel low frequency amplifier .25MHz to 1.5MHz with 30dB gain.
    We used this site with these inputs(fc=1000000, B=500000, A=7.5, C=.470), but it doesnt we dont have enough gain for our range. Any ideas? Thanks in advance!
  2. studiot
    Nov 9, 2007
    5,005
    515
    Need more data
    Impedance level of signals?
    voltage level of signals (are they voltage or current; some ultrasonic transducers are current driven)?
    is signal earth referenced?
    Load impedance to be driven?
    What op amp did you try in your simulation?
  3. thetallstewy
    Oct 30, 2009
    7
    Used a 741 opamp. Our peak to peak is .4V.
    The transducers are powered through circuitry. We are using Olympus immersion trandsducers V303 and V301.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Can you be serious? -
    And you say -
    - to cover the range
    - with -
    This is less than believable. Look at the specs on a 741.
  5. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Whenever I see "We" it's either a school project or the Borg. The Borg stopped using the 741
  6. ELECTRONERD
    May 26, 2009
    1,146
    16
    I'll second that, are you serious!?
    Any ultrasound receiver is going to require a high-speed op-amp. I'd find the right op-amp first that can concur with your application before anything else.
    Austin
  7. studiot
    Nov 9, 2007
    5,005
    515
  8. thetallstewy
    Oct 30, 2009
    7
    Please be constructive all. For the past 5 years, in every lab with op amps, I have used the 741, and actually my labs suck at teaching the "guts" of an op amp, so I figured it would be a start.
    So studiot, I will check out those series, thank you.
  9. thetallstewy
    Oct 30, 2009
    7
    Alright, so I looked through the op amps I have access to and best I can find is the TL0xxCP series. Are these fast enough or do I have to order the LT1630? Thank you
  10. ziouranio
    Member
    Jul 23, 2009
    20
    Hi, I usually work with ultrasound for diagnostics and when performances are the issue nothing can beat specific purpouse IC devices.
    They are costly but if your application is not a consumer device but a high-end product such as for medical diagnostics or test equipment, the time you will save in design phase and the increase in performances will pay many times the cost increase.
    Some yars ago I used the AD600 (Analog devices) that is a 2 stage amplifier up to 40+40dB with 35MHz bandwidth. The interesting thing is that you can change the gain from 0 to 80dB with a plain voltage control (like the DAC output of your MCU).
    I also used AD603 (90MHz) and the logarithmic AD606 with great results. The only problem is prince, ranging from 20-30$ for AD603 to more than 100$ for AD606.
    I am going to use the 40MHz VCA2614 (Texas Inst.) for my next designs or its 80MHz VCA2616 brother.
    Choosing one of these IC you will only need an impedance buffer front-end for the piezoelectric transducer, any JFET input op-amp with low noise and suitable speed will be a proper choice for this.
    Hope this helps.
    Philip
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The TL0xx series are basically for the audio range. A TL07x gain bandwidth product is 3MHz (that's with unity gain, or gain=1) - you need 10x that bandwidth.
    The LT1630 should work for you.
