I am trying to use a particular tilt switch which only has 1ma out to control an LED. How would you use a 2N7000 transistor or other gate component to allow the real current 20ma to pass to the LED and not cook the tilt switch? Here is the dsheet:
http://www.components.omron.com/components/web/PDFLIB.nsf/0/F8EBDDB7A51A229C8625730D0076401A/$file/D6BN_0307.pdf.
Battery is 3.7v Also, no matter what solution is found it needs to be very small.
