low current measurement of pico amps
Discussion in 'General Electronics Chat' started by nvssaravanan, Feb 3, 2011.
  1. nvssaravanan
    Oct 4, 2010
    HI all,
    I want to measure insulation resistance in the range of pico amps.
    i want to convert it to micro amps for mega ohmmeter indication.
    the test voltage for the measurement is about 27V DC.
    The mega ohmmeter working current is about 0 - 200mA.
    Which IC i have to use for amplifying the current for the above measurement.
  2. Adjuster
    Dec 26, 2010
    2,147
    300
    Have you made a mistake with that meter current? A 1MΩ resistance measured with 200mA test current would dissipate 40W.
    To pass 200mA into 1MΩ, the test voltage would need to be 200kV!
    Perhaps you have a meter which also measures much lower resistances, with a higher test current?
  3. kubeek
    Sep 20, 2005
    4,688
    806
    More like 40kW :eek:
  4. Adjuster
    Dec 26, 2010
    2,147
    300
    Quite so - my mistake.
