Low cost LED Driver
Discussion in 'The Projects Forum' started by Budman231, Dec 19, 2012.
  1. Budman231
    Dec 22, 2011
    13
    Hi.
    I was hoping someone could recommend an LED driver that could help me bring down the cost of my projects. I've been using a Buckpuck 500Ma driver that can dim and strobe. Link is here (http://www.ledsupply.com/03021-d-e-500.php). It's really great product but is costly especially since I use 2 of these per project.
    I was hoping someone could recommend a driver that matches these specs.
    1. <$8.00
    2. 500mA
    3. 6v Input (4xAA)
    4. Dimming/Strobe/OnOff Capability
    5. <20mm square if possible
    Thanks in advance,
    Bud
  2. John P
    Oct 14, 2008
    1,638
    225
    Go to eBay and look up "LED driver". There are a lot of cheap little things available amazingly cheap from Chinese vendors. There's a lot of variety; you might find something with the right specs.
  3. mcgyvr
    Oct 15, 2009
    4,789
    975
    Avoid the Ebay Chinese crap like the plague..
    Look into Meanwell LDD series drivers.. they do exactly what you want and are sub $8 for sure..
    In general LED supply is a ripoff.
  4. crutschow
    Mar 14, 2008
    13,496
    3,373
    Why do you say that? :confused:
  5. mcgyvr
    Oct 15, 2009
    4,789
    975
    Because their prices are higher than others.. simple.
    Unless something has changed in the last year.. I was routinely running into products that I needed/wanted on their site. I always found it cheaper at others.
  6. John P
    Oct 14, 2008
    1,638
    225
  7. Budman231
    Dec 22, 2011
    13
    I would seem that the LDD series starts at a minimum of 9vDC. I do need a driver that works with 6vDC. I have to say you are right in that they do have all the other specs I need..
    Bud
  8. DickCappels
    Aug 21, 2008
    2,770
    669
    Just a note: While on the Chinese LED supplier topic, be careful when buying white LEDs directly from Chinese suppliers for commercial projects. All white LEDs are currently covered by a myriad of patents; one reason some white LEDs from Chinese suppliers seem to be so cheap is that the price does not include the licenses necessary for sale and use in, for example, the United States.
    absf likes this.
