Low cost 12V/6A dc-dc for lead acid
Discussion in 'General Electronics Chat' started by Vindhyachal Takniki, Oct 9, 2016.
  1. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    1. I have a lead acid battery in my board. It needs three outputs: 12V/3A, 12V/3A , 5V/2A. For first two outputs, I will keep single 12V/6A
    2. For 5V/2A I will use LM2576 in front of lead acid battery.
    3. Since lead acid battery varies from 10.5V to 14V. For getting 12V/6A output. I need some cheap & low component board for it. Efficieny is not as issue here for me. Not want that should be 90% or higher.
    Only thing is low cost, like LM2576, only few external components are required.
    System should also have a low voltage cut off at 10.5V, otherwise it will drain the entire battery.
    4. I had serached for many system. They are all very expensive & also TI webbench also suggest costly systems.
  2. ronv
    Nov 12, 2008
    3,403
    1,477
    If you are in the US look at ebay. Something like this with a little fan might be a good deal.
    http://www.ebay.com/itm/Automatic-B...id=100033&rk=2&rkt=3&mehot=ag&sd=141723797418
    Vindhyachal Takniki likes this.
