Haha, thanks, they are just there to indicate that they are outputs.If the arrows are the diodes, they are drawn in the wrong direction.
Ken
Thanks again, Phil.
Ken
If the voltage were to raise to 14.14 volts what would happen to the resistor? atm it runs only slighly warm at 13.8V would it burn out or just run too hot?I can understand the 2W 100 ohm resistor since it takes only 14.14 volts to yield 2 watts. The 2W 10K and the 1W 47K resistors will take 141.4V and 216.8V respectively before their power ratings are exceeded.
Better safe than sorry.
hgmjr
The reason for 5V is to allow for the 2V excess voltage, this take it to 7V minimum operation. If I were to raise to 9V this means that the minimum operating voltage would be 11V, this would be too high for my application.Raise D2 to 9V, as there is no real advantage to 5V, and R1 will not have to dissipate as much heat. Put a 1K resistor between T1's emitter and T2's base. With both turned on, you are essentially shorting the voltage at D1 to ground.
Ken
Hi Ken, thanks for your time.Your original spec was 12v to 30v. You then changed it to 11V to 28V. Does it really need to operate down to 7VDC?
All resistors except R1 can be 1/4W.
Have you tried R1 at 28V?
P=((28-5)*(28-5))/100=5.3W
That's 230mA. Do you know how much current the circuit will draw? R1 might be able to a much higher value, dissipating less heat, both in R1 and D1.
Ken
What does the ORing diode connect to? Did I miss something?Ron,
I think the OR-ing diode D4 will protect the MOSFET from the relay's flyback voltage.
