Hi all.
I want to make a simple circuit that powers a load from a 12V battery and this circuit switches the power to the load off when the battery's voltage decreases under 10.5V. I prefer to use a MOSFET to switch the load ON and OFF instead of a relay.
I've built a simple circuit using the LM358 comparator and MOSFET IRFZ44. The current that the load draws is few amperes so IRFZ44 is ok as it's price is also good (0.3$).
The problem that's facing me now is when the battery's voltage becomes approximately 10.5V. The preset pot. is set to 5V on pin 3 when the source/battery voltage is approximately 10.5V. So at that point the output if the comparator starts to decrease to become LOW. This decrease means that Vgs is decreasing and so the voltage across the load decreases instead of switching off directly. This also makes the MOSFET get very hot if the period is long...
May be I need to add hysteresis to the comparator but I don't know how to get the value of the resistor and I don't now if his may help solve the problem.
Any help is strongly appreciated.
Regards,
Hazim
Regards,
Hazim
