Hi Folks,
I am about to start a very small project which is to add a little pre-amp circuit internally into my acoustic guitar. The guitar already has pickups and a passive tone/volume control, so I want to add the pre-amp just after that existing circuitry and before the output jack.
The pre-amp (which is a very simple well known circuit off the web) runs off a 9 volt battery and will work even if the battery voltage drops to 8 volts ... what I am concerned about is what happens after that as I believe when the battery decays to a certain voltage I will get no signal whatsoever at the output jack.
Now that would mean that whilst playing, if the battery decays I will end up un-plugged ... which is not good ... although others may disagree!
I guess I could simply put a manual SPDT switch on the signal input which would either send the signal into the pre-amp or directly to the output jack, but was wanting to avoid drilling another hole into the guitar body.
So I was wondering if there was a way to replace that manual SPDT with an electronic version that could automatically detect a low voltage condition (maybe fine tunable with a trim pot) and flick some sort of electronic switch that would route the signal direct to the ouput jack?
I have attached the pre-amp circuit I plan to use with some (awkward looking) red lines and text I have added showing what I mean.
I am looking for the most simplest solution possible as I want to keep the component count down to a minimum, plus I am also looking for a solution that does not add to the problem by draining too much battery power.
Any help would be much appreciated.
Thanx
Zig
Thanx
Zig
