Loud White Noise Generator
Discussion in 'The Projects Forum' started by daghettoalbanian, Jul 2, 2013.
  1. daghettoalbanian
    Jul 1, 2013
  2. crutschow
    Mar 14, 2008
    13,482
    3,368
    Just run the white noise output into the input of an audio amp and speaker. You get a similar white noise effect if you tune between stations on an FM tuner with no squelch.
  3. #12
    Nov 30, 2010
    16,671
    7,314
    No. First you make white noise, then you amplify it, then you put that into a speaker. A white noise generator doesn't have a speaker. It's like asking if anyone knows of a cow that gives cheese. No, there are several steps between cow and cheese, and there are a couple of steps between white noise and "loud".
  4. DickCappels
    Aug 21, 2008
    2,766
    667
    This circuit with a full bridge output should be able to drive a decent pair of headphones way past 90db mw SPL.
