lost, can anyone please help with DPDT wiring?
Discussion in 'The Projects Forum' started by lostintranslation, Nov 6, 2013.
  1. lostintranslation
    Nov 6, 2013
    37
    trying to wire in part of a circuit option to let me switch from 1000 CAPS, adding additional 1000 CAPS that are wired in parallel using a DPDT ON-OFF-ON toggle, but, not quite sure how to wire it. I can read the circuit, but applying it to the poles on the switch for the circuit are a little tough for me to figure out right now. I'm learning. Thank you very much in advance for any help, it is really [​IMG]appreciated.
  2. Bernard
    Aug 7, 2008
    4,240
    414
    With a center off DPDT SW as shown, looks tike it works
  3. lostintranslation
    Nov 6, 2013
    37
    yes, Toggle to center OFF should let one CAP work, Toggle to on in one direction should kick in 2 CAPS, and the toggle to the other on position should engage all three. the circuit diagram is good, but how would you actually wire the switch? sorry, trying to figure it out. i have the ability to read the circuit, but applying the wiring in the right order is tricky for me, any help is greatly greatly appreciated. thanks very much.
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    Here it is:
      File size:
      80.6 KB
      25
    lostintranslation likes this.
  5. lostintranslation
    Nov 6, 2013
    37
    can't thank you enough. I do graphic design for a living, so a picture is worth a thousand words. and a thousand thanks to you sir.
  6. MikeML
    Oct 2, 2009
    5,451
    1,066
    The trick is knowing that the middle terminals b & e are the commons, and that a-b-c form one pole, and d-e-f is the other.
  7. lostintranslation
    Nov 6, 2013
    37
    the D switch pole is empty? no wire? just asking, for confirmation, not questioning. thank you
  8. MikeML
    Oct 2, 2009
    5,451
    1,066
    Yep, look at the schematic in your original post. Notice the pole with no connection to it...
  9. lostintranslation
    Nov 6, 2013
    37
    the CAPS and switch are part of a larger circuit I am trying to build, as part of a small specialized arc welder. If I post up pics of the circuit, would you mind taking a look at it please? I had it working successfully before I introduced the DPDT and optional CAP set up. Now I am back to square one. I have spent the last few days struggling with this...sorry to bug yah, really appreciate the expertise, I am lacking it. lol, thank you again for the help on the switch, It was greatly appreciated.
