Draw it out. Loose your neutral and your loads are in series. Apply the math and reconsider the question.Dear Members,
As far as I know neutral loss in a 3 phase system causes the voltage of the phase with less load to rise and that with higher load to fall.
Please i want explanation as to why and how this happens.
thank you
For me that statement is too general. The loss of neutral connection, such that current is unable to return to the 3-phase source via the neutral conductor, immediately imposes the condition that the line currents must re-adjust to allow for the loss of neutral current. The vector addition of the individual 3-phase line currents must be zero to satisfy this outcome. This may, for instance, result in a lower total 3-phase power delivery from the source in relation to the case with the neutral intact.Dear Members,
thank you
An interesting concept. Perhaps you could give a specific example of conditions in an unbalanced 3-phase system before & after neutral loss. I imagine something like an unbalanced 3-phase Wye connected load fed by a balanced Wye connected 3-phase source with the Wye load neutral point returned to the source neutral in one case and not returned in the other case.Or just some simple deduction. Regardless of the value, a poly phase system with neutral will keep the voltages equal across the individual loads. Loss of neutral puts the loads in series, where classical voltage drop equations paints the picture. Don't worry about the numbers themselves, but the relationships.
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Jake Hertz
