Loosewire...YOU SANDBAGGER!!!!!
Discussion in 'Off-Topic' started by mbohuntr, Jun 11, 2011.
  1. mbohuntr
    Thread Starter Active Member
    Apr 6, 2009
    413
    32
    Everyone needs to read loosies reply on the Electronics chat 480 volt thread. That is the most coherent and thought-out post I've ever read from him. No meanderings, no interpretation needed.
    What gives??? You been foolin' us...aint ya.....;)
  2. mbohuntr
    Apr 6, 2009
    413
    32
    loosewire [​IMG]
    If all the leg's are the same,post a diagram to show what you are working with.
    Having that difference in amps should show something in brightness.
    Also be careful until you figure It out. Have you checked all the grounds
    for bad connections.Let us know what you find.If every thing is showing ok
    what brought the problem to your attention,what I am saying If the brightness
    was all the same,why were you testing.Where did your complaint come from.
    (just in case he deletes it ;) )
  3. loosewire
    Apr 25, 2008
    1,584
    435
    Thanks for drawing attention to Loosewire,If all the lights were the
    same bightness. Why was he doing the testing.Did he just finish the
    Installation,who knows. My mind works different,that the Loosewire.
    Do a little self evaluation before you take on the Loosewire,you have
    task before you now.Where the cause of the problem,where your answer
    to the problem.Leave the Loosewire to me.I don't need to delete anything.
    I should post more and I will to please you,you are messing with the greatest.
    I didn't find your answer there,you spoke too soon,no post either,what gives.
    You just give my picture In the Atlantic Ocean more exposure.
    The water was beautiful that day,one of the best photo's of man and ocean.
  4. mbohuntr
    Apr 6, 2009
    413
    32
    Truly a devious mind, and a worthy opponent.... I will be watching you for more clear comments and statements that reveal your hidden self. :D
  5. loosewire
    Apr 25, 2008
    1,584
    435
    Don't touch the Loosewire.
  6. DumboFixer
    Feb 10, 2009
    219
    34
    There is but 1 Loosewire
  7. shortbus
    Sep 30, 2009
    4,084
    1,664
    but remember loose wires sometime short out :)
  8. Kermit2
    Feb 5, 2010
    3,838
    961
    Even a broken clock is right twice a day.
  9. t06afre
    May 11, 2009
    5,939
    1,222
    By all means we leave it to Loosewire to touch him self.
  10. magnet18
    Dec 22, 2010
    1,232
    125
    The best "right" clock is always off a little bit. All the time.
