Looking water fish tank water level sensor
Discussion in 'Embedded Systems and Microcontrollers' started by stacaz, Feb 17, 2015.
  1. stacaz
    Sep 2, 2010
    I have researched, but found nothing like the outside mounted RV water tank level sensor like See Level has. I am looking to sense the water level in a fish tank, from the outside, and am using a PIC32 controller to drain and fill the tank via 12v solenoid valves. I want to monitor, as well as drain to a certain level, then fill to a level. My PIC32 is programmed on a timer to do this every other day. I am tired of relying on float valves. My turtle tends to disrupt it often.
    Thanks!
  2. mitko89
    Member
    Sep 20, 2012
    123
    19
  3. Flare_Guy
    Nov 18, 2012
    13
    Water level measurement can be done by pressure. The best unit is inches of water.
