Did you want me to argue with all that guff or agree with it? Because he's got some bits right and some bits that sound confused.
However nothing you pasted there changes the calcs I posted before. I've seen the specs of your motors, and of your 5410 drivers. Your proposed 36v unreg 150W PSU is plenty and it's a good match for your motors and drivers.
RB, I just wanted to show how they figure it on forums that all they deal with is steppers. I mean NO disrespect to you just trying to understand this stuff better. As my screen name says I'm on the short bus learning this stuff!
There are some problems with the numbers being used in this thread.
Motor; 7.9Amps/phase Resistance- .41Ω/phase
The motor is also marked 65V(this is the max. voltage)
7.9Amps
337Watts
Max amps for driver 5Amps 36Volts
Now using your formula: Amps squared*Ohms = Watts
5*5*.41= 10.25W * 2phases = 20.5W
Out of all the Watts formula why use that one? Wouldn't P = V*A be the one to use? 36V*5A =180W * 2phases = 360W
This is more in line with what is used with all the other information I have ever seen for stepper drives. I know I don't have even a minuscule amount of the electronics knowledge that you do. So please help me to understand and get my thinking right!
While I'm at it, why don't the answers to the Watt formula come out the same? How do you know which one to use? The only one i use is P=IE so I never realized that you don't get the same result!
