Looking For Website/Information on sensor
Discussion in 'Electronics Resources' started by NoLiver92, Oct 11, 2013.
  1. NoLiver92
    Oct 11, 2013
    I am making a model sailing boat and i want to attach a wind direction sensor BUT the problem is as its only a model the sensors i have found are way to big to go on it.
    I am wanting to find a small sensor to fit onto this model, and i would appreciate it if someone could point me in a direction to look at as i have ran out of ideas.
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    Oooh, that's a tricky one.
    The first thing that comes to mind that is really small enough to sit on a model sailboat is a hot wire anemometer.
    One anemometer will measure air flow. I think it is doable using four such hot wire anemometers in order to determine direction of air flow. It might be tricky though, not for the faint of heart.
  3. Alec_t
    Sep 17, 2013
    5,967
    1,135
    Perhaps a small wind-vane with optical encoder attached, read by photocell(s)?
    On second thoughts, that might be affected too much by gravity as the boat heels over.
  4. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    How about looking for a 360° continuous miniature pot? Bourns make some nice ones.
    I assume you want to mount at mast head?
    Making a light vane would be up to you!
    Max.
