What would be the simplest way to accomplish this, using a couple timers and cmos chips?
Would like to avoid programming methods at this time. It's been too long since I've worked with pic etc.
An ideal solution would be a couple 555s or retriggerable timers, maybe a gate or two.
Taking a signal from hall sensor, <10hz to ~400hz, output follows input in frequency. Duty cycle and symmetry not important. It just goes to a processor that tracks rpm and total rotations.
When reaching a set frequency, say 350hz, output continues, but limits to 350hz maximum.
Intuitively it seems a retriggerable configuration would work, up to a set point, then output would remain "high" at speeds over set point.
That high could be used to switch, somehow, to a 350hz clock output.
Also considered d-a converter and a-d conversion with high limit.
Lost in the details. Have not yet come up with anything worth testing.
