Can anyone give some suggestions of what project i will make.
Please send me the diagrams of your best suggestions. Thank you!
Using the 555 timer what circuit will i make sir.? Is it only a blinker circuit? Any suggestions pleasrThis is a terrible question. How do you define "best"? What kinds of projects interest you?
Once again:Using the 555 timer what circuit will i make sir.? Is it only a blinker circuit? Any suggestions pleasr
NO, doing a radio receiver ...Make a motor speed controller. That is the BEST project.
Wait, PWM communication of a AUDIO signal with IR Emitter and phototransistor. That is the NEW BEST project.NO, doing a radio receiver ...
If you want to do the PWM communication, what uC will you choose, or using a arduino is easier and can be settle down many things in computer.Wait, PWM communication of a AUDIO signal with IR Emitter and phototransistor. That is the NEW BEST project.
So you just want to do a interface of PWM communication?No way, totally analog - put the audio signal into the CONTROL pin of a 555 timer and get PWM output, drive the IR Emitter.
On the other end, just an OP amp and low pass filter and away you go.
One that works as needed?How do you define "best"?
Any chance of the schematic?
AVOID TALKINGELECTRONICS AT ALL COSTS!One that works as needed?
http://www.talkingelectronics.com/projects/50 - 555 Circuits/50 - 555 Circuits.html
Max.
by Jake Hertz
by Jake Hertz
by Duane Benson
by Aaron Carman
