Looking for soldering iron with solder feed
Discussion in 'General Electronics Chat' started by Th3RadMan, Jun 13, 2016.
  1. Th3RadMan
    Jun 13, 2016
    5
    I have a reduced motor skills on the right side of my body due to cerebral palsy. However, I want to learn how to solder. I think an iron with some sort of automatic feed would be extremely helpful for me, otherwise, I might as well say forget it. I've seen a couple, like this one, however, I'm not to fond of the 0 reviews it has, along with other feeding irons on amazon. Any recommendations for an iron with an auto feed?
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    Sometimes when I need a third hand, I hold the solder in my mouth (lips).
    John
  3. mcgyvr
    Oct 15, 2009
    4,791
    976
    Tape a mechanical pencil to the iron.. feed the solder through the tip..clicky..clicky.. voila :)
    Quality solder feeders aren't cheap... Got a budget to work with here?
    In reality any of the "off brands" on Ebay aren't too bad but no guarantees there..
    or
    You could pick up a used Hakko (quality brand) unit for as little as $100 on Ebay...
    New units are 3 to 4 times that on average..
    or
    Find a good auction.. You can usually find them cheap..
    Personally I'd just build one.. A few tubes, a motor, a few gears/wheels, and a switch.. Fun little electro-mechanical project to get you started..
    oh and Don't put the solder in your mouth..
  4. Lestraveled
    May 19, 2014
    1,957
    1,218
    Soldering is a skill that takes time for anyone to master. I learned it using two hands. You can learn to do it with one hand, without that strange auto feed gun. I don't know, it might work great, but you can improvise with a regular soldering iron. You may have to use a spudger soldering tool or a micro gripper in your mouth. You can use a "Pana-vice" as a second or third hand. There is a technique called "re-flow". You tin the part, you tin the location, then get them close together and apply heat.
    There are a lot of tools out there to help you. It is your disability, you figure out how to conquer it.
    It takes much more patience and practice, than the use of a second hand, to solder well. I am certain that you could be a better solderer than most of the two handed people I see solder.
    My advise, find a well stocked electronics supply store. Look at the soldering tools, accessories, vises, holders etc., and figure it out. Don't buy the cheapest soldering iron, nor the most expensive. There are a lot of how to solder videos on the internet, watch them.
    When you start getting good at soldering, post some photos and tell us how you do it.
