Looking for Relay-like device
Discussion in 'The Projects Forum' started by snowtsuku, Jan 4, 2015.
  1. snowtsuku
    Jan 4, 2015
    I would like to start a project, however I'm not yet sure with the materials and devices that I want to use. The project's main objective is to create a dot patterns similar to the dice. Instead of having LEDs to display the pattern, the project will push something to create the pattern. Is there a device that produces linear motion when voltage is applied. It only needs to have a push or no push kind of thing, like a relay.
  2. bwilliams60
    Nov 18, 2012
    734
    94
    How about a solenoid? Not sure what you are doing with the limited amount of information but a solenoid has a linear push/pull effect. How much movement you will need, voltage/amperage/source etc you haven't provided so may need some more information.
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    You can make a mask with 7 holes, two columns of three and one in the middles. Then rotate a drum with black patterns behind it to give the different results. That is a very old-fashioned type of indicator. John
