Looking for Op Amp 5534
Discussion in 'General Electronics Chat' started by frenchie29, Jan 21, 2009.
  1. frenchie29
    Thread Starter Active Member
    Nov 28, 2008
    134
    I usually get all my chips on ebay but not that one
    Anybody knows where I can get a 5534 op amp? All my google results are linked to forums or specs but no sales!!!
    Thank you
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Digikey has the NE5534A opamp.
    hgmjr
  3. frenchie29
    Nov 28, 2008
    134
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    There are few op amps left that perform as poorly as a 741. Choose an op amp made for audio applications, like the OPA134.
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    Don't buy cheap counterfeight parts on E-Bay.
    By genuine real parts from an electronic parts distributor like Digikey.
    The NE5534 is a much better single opamp than a lousy old 741 opamp. An OPA134 or TL071 are also good single opamps.
    They all have the same pins numbers as a 741.
  6. frenchie29
    Nov 28, 2008
    134
    I just bought 25 5534s for $23 from Digikey
    If I get the OPA134 would I need to change any components from that kit? With the 5534 it's just a chip swap with the 741
  7. Audioguru
    Dec 20, 2007
    9,411
    896
    They all have the same pins numbers.
  8. frenchie29
    Nov 28, 2008
    134
  9. Audioguru
    Dec 20, 2007
    9,411
    896
    Compare the datasheets of the very old NE5534 to the newer OPA134:
    1) They both have a wide range of supply voltages.
    2) They can both drive a load as low as 600 ohms.
    3) The datasheet for the NE5534 does not mention distortion but I think it is pretty low.
    The OPA134 has 0.00008% distortion.
    4) The NE5534 has a full supply voltage max frequency of 100kHz. It is 230kHz for the OPA134.
    5) The NE5534 has input junction transistors so its input impedance is not very high and its noise at high source resistances is high.
    The OPA134 has FET inputs so its input impedance is very high and its noise is low for any source resistance.
  10. frenchie29
    Nov 28, 2008
    134
    I changed the original 741 for a 5534 and a 134 and it's clean like a whistle
    the 134 is a bit "warmer" but has less gain then the 5534
  11. Audioguru
    Dec 20, 2007
    9,411
    896
    The NE5534 has a typical internal gain of 100,000 at 1khz.
    The OPA134 has a typical internal gain of 10,000 at 1kHz.
    When negative feedback is added then the gain for each is the same.
