Looking for LM358 replacement
Discussion in 'General Electronics Chat' started by waldopulanco, Dec 3, 2013.
  1. waldopulanco
    Nov 14, 2013
    26
    I am looking for LM358 Replacement, that there is no change the value of resistor or other component for the use of LM358. but low distortion and high frequency which is about 100khz and sigle supply almost similar to LM358 dual opamp.
    according to an expert the LM358 is
    The lousy old LM358 has problems above only 2kHz so it should never be used for audio.
    The lousy old LM358 has crossover distortion so it should never be used for audio.
    thanks in advance!!
  2. bountyhunter
    Sep 7, 2009
    2,498
    507
    This is similar, but has lower max voltage rating. You did not give specs so there is no way to select a suitable device.
    http://www.ti.com/lit/ds/sbos309d/sbos309d.pdf
    The J-FET op amps like TLO81 have very good AC performance but require dual supplies.
    waldopulanco likes this.
  3. bountyhunter
    Sep 7, 2009
    2,498
    507
