I am planning on using a LTM4605 for building a voltage regulator. It will be built as a PCB, but I would like to first be able to do some breadboard testing. The trouble I'm having is that the LTM4605 is in a LGA package. Is it possible to do breadboard testing with that? My searching has only come up with LGA to DIP adapters, I'm not sure if that's what I need. I'm also seeing that it varies from LGA-8 to LGA-28, but I can't find anything in the datasheet that shows which one the LTM4605 is, it just says LGA. Is the number supposed to be the number of leads?
