Looking for LCD polirizer
Discussion in 'General Electronics Chat' started by R!f@@, Jan 6, 2015.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,785
    771
    I am not looking for LCD TV or phone polarizers but those type found in small LCD's used in calculator.
    Need to replace some worn out polarizers in these type of numeric display type LCD's.
    They are clear type u know.
    Any one know where I can buy some of these polarizer in around A4 sized sheet
    Darn! I cannot change the typo in the thread topic. It was much easier in the early software version of the forum
  2. cmartinez
    Jan 17, 2007
    3,698
    2,759
  3. RichardO
    May 4, 2013
    1,335
    429
    Most modern LCD's have the polarizer bonded to the glass. Could be hard if not impossible to replace. Maybe just adding the new polarizer on top of the existing one will work if the extra thickness can be tolerated.
  4. R!f@@
    Apr 2, 2009
    8,785
    771
  5. cmartinez
    Jan 17, 2007
    3,698
    2,759
    All LCD's require a polarizing filter so they can be seen, in fact, any polarizing filter will do, I've even used polarizing plastics from cheap sunglasses to do this before. All you'd have to do is cut the shape you need from those films and you'd be ready to go. Though I'd probably buy these instead, they seem thicker and of a better quality than the ones for the iPhone.
  6. R!f@@
    Apr 2, 2009
    8,785
    771
    Ya..those seems fine..but Amazon does not ship to Maldives now....!
    Wish they were on Ebay.
  7. cmartinez
    Jan 17, 2007
    3,698
    2,759
    man... sorry to hear that... that must be frustrating...
  8. RichardO
    May 4, 2013
    1,335
    429
    Keep in mind that the direction of the polarization is important. You must have a polarizer sheet large enough to rotate to any angle and still cover your entire display.
  9. cmartinez
    Jan 17, 2007
    3,698
    2,759
    Yes, I was assuming that the OP knew about that... but then again, as the old saying goes: "Assumption is the mother of all f***-ups"
  10. R!f@@
    Apr 2, 2009
    8,785
    771
    Thanks...I know about how it should be...
    Still searching....
