Why is that? Where is that? What is the 12 volt circuit, and the load in amps?Needs to be weather resistant and tamper proof.
You could put it in an outdoor safe.Needs to be weather resistant and tamper proof.
The hall effect sensor for the speedo is on the trans output shaft. I want to use the signal from this sensor to switch a relay for the injector driver circuit on and off at 25mph. Off above 25mph and on at anything below 25mph.
Yes,signal is proportional analog depending on the output shaft speed
by Duane Benson
by Don Wilcher
by Duane Benson
