Looking for HIP4020 - power bridge driver
Discussion in 'General Electronics Chat' started by pcharters, Jun 27, 2007.
  1. pcharters
    Jun 23, 2007
    I am working on a small private project that requires isolated power supplies and have found an Intersil device - HIP4020 - that would make a perfect power driver. However, I cannot find a distributor anywhere on the internet that sells in small quantities.
    This is an "H" bridge driver for loads to a maximum of 15V and currents of no more than 500ma. It sells in the $2.00 range. I only need one but would buy three or four in order to have spares.
    If anyone knows of a distributor in either Canada or USA, please let me know.
    Pete
  2. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
  3. pcharters
    Jun 23, 2007
    The first item you listed is more complex than I need. The second URL you provided told me that "the dataset has expired" so I never actually saw any detail on the part.
    However, something i saw in the data you sent gave me the idea to search in a slightly different way. As a result, I found a Vishay/Siliconix IC (Si9986) on the Allied website that will do the trick very well - under $3.00, 8 pin and easy to interface.
    Thanks very much for your help.
    Pete
  4. mrmeval
    Jun 30, 2006
    833
    Cool. I would appreciate seeing schematics of your final design. I have two four wire stepper motors from laptop floppies that I'd like to tinker with.
    I thought I'd picked that link right but Digikey does not make them easy to share. :(
  5. pcharters
    Jun 23, 2007
    The Si9986 will certainly operate a small stepper - up to 1A at up to 13V and up to 200 kHz frequency; inputs are TTL.
    I am using it to supply power to a number of small amplifiers which have to be isolated from the main circuit and from each other so I am pumping through capacitors.
    I'll let you know if it works but it may be a couple of weeks or more before I know.
    Pete
