Looking for help
Discussion in 'General Electronics Chat' started by jstrike21, Jun 10, 2010.
  1. jstrike21
    Sep 24, 2009
    104
    Hi, I'm currently going into my Junior year as an Electrical Engineering major and I just learned that I could get a double major in EE and Mathematics with a few extra classes. My question is, would it be beneficial for me jobwise to go after this?
  2. retched
    Dec 5, 2009
    5,201
    313
    This is an, "Only you can answer" question.
    The more documented knowledge you have helps. But, If double majoring is going to effect your grades in the other major, you are better off "specializing".
    If you get a 4.0 in your EE, it is better than getting a 2.8 in EE and 2.8 in Math.
    You can ALWAYS take the other classes later. Dont overwhelm your studies if it is going to affect your GPA.
    Workload is a killer.
    If you find you are having a problem in the job search, go back and take the math classes. You may be able to test out of many of the classes if you know the material and shorten and lighten your workload.
  3. mcgyvr
    Oct 15, 2009
    4,791
    976
    the more degrees the better IMO.. it surely can't hurt.
  4. Bychon
    Member
    Mar 12, 2010
    469
    41
    Burn-out can hurt.
    I was so burnt out in my third year that I had to take a semester off.
  5. JimG
    Member
    Dec 7, 2009
    53
    Don't pursue the additional degree. You'd probably end up in at least a few courses that have little relevance to engineering.
    Do take as much math as you can fit into your schedule -- particularly applied math. The knowledge gained here will be more valuable in the long run than the extra credential.
    Jim
  6. Dalaran
    Dec 3, 2009
    168
    I just finished a degree in Engineering Physics and Management. It combines a an engineering major with a commerce major. I quite enjoyed it. The work load was only an extra 2-3 classes per year (and 5 years instead of 4) and taught me many things I would not have learnt otherwise. I believe it definitely help me get a job.
    I say if you are interested in the 2nd major, and don't believe it will majorly affect your other courses learning/grades, then go for. If your in doubt however then scrap it, you can always take them later.
  7. Tobias
    May 19, 2008
    158
    I have a CIS degree. I graduated with a 2.95 GPA. The summer before I graduated I was awarded an internship at Anderson Consulting (Accenture now)
    I found out I had the lowest GPA out of all the applicants. I got the internship because of my wide range of work experience (none of my previous work experience was IT related) and good BS skills, BS meaning I can have a conversation with about anyone.
    After I graduated I was offered alot of great jobs and it was mainly because of the internship and work experience. I really think that anymore, GPA is good but employers have found that GPA isn't the only thing to hire someone. I would say you can't go wrong having another degree. Either one or many degrees, .... work your ass off getting an internship. That will set you apart from your peers because you can prove you are already hire-able to employers.
