Looking for help with using an LM339 comparator
Discussion in 'General Electronics Chat' started by dc@nsac, May 28, 2009.
  1. dc@nsac
    May 28, 2009
    Howdy,
    I'm trying to take the output of a soil moisture sensor, which is a square wave frequency (~100-600kHz) of +/- .7V
    and eventually put it into a wireless DAQ, that only likes voltage.
    Here's what I've pieced together:
    the freq-to-volt chip only goes to 500khz, so i added a binary counter to divide the freq by 2.
    but the counter doesn't accept a frequency with such a low power (+/- .7V),
    so i was given advice to run the frequency through a comparator to achieve a square wave with 0 to +12 V amplitude (rather than -.7 to .7).
    I'm using an LM339 comparator, and have no idea how to do this. Can anyone help me out?
    Also, does anyone know of any good faq's or help for frequency to voltage chips? (I'm using an ADVFC32 chip)
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    Can you post a schematic?
    The ADVFC32 has a logic output that has to pulled up with a resistor.
    Greetings,
    Bertus
  3. mik3
    Feb 4, 2008
    4,846
    63
    If you want a 12V peak output from the comparator use a dual 12V supply. Connect the inverting input to ground and the output signal of the sensor to the non-inverting input. The output will be in phase with the input signal. If you want a 180 degrees phase shift connect the comparator inputs the other way round.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If you just want to convert your -0.7v to +0.7v square wave to a TTL-compatible signal, try the attached circuit.
