Looking for help on a simple push-button delay design
Discussion in 'General Electronics Chat' started by JerryH, Jan 10, 2011.
  1. JerryH
    Jan 10, 2011
    7
    Hello all, I'm new to this site so I hope I posted into the correct forum.
    I've been trying to locate a sample design that would allow me the following function: Push a button and immediately send an "on" pulse...if I continue to hold down the button for another full second, start sending pulses at about 2/3 times per second until I release the button.
    This kind of functionality is common on appliances, such as holding the Up/Down Channel buttons on a TV remote, or to quickly set a digital clock.
    I get the feeling the ubiquitous 555 would be used in this scenario, but I've just too many gaps in my knowledge. Thank you!
  2. #12
    Nov 30, 2010
    16,703
    7,338
    More than one 555 (also known as a 556). Let the pushbutton send the first pulse (capacitively coupled) while starting "Timer one", a 555 configured as a one-shot. When timer 1 clocks out in one second, it allows a second 555 to start oscillating at 2/3 Hz.
    Meanwhile, the button did an enable function, so when the button is released, everything stops.
    That's a block diagram. The schematic comes next.
  3. KMoffett
    Dec 19, 2007
    2,584
    234
