Here is the modified schematic:
^ I don't think it should be saturated here, I think it should be in cutoff?OK, your 1st image.
Q1:
Ve=12.17, Vb=11.47, so Vbe=-0.7v.
Ve=12.17, Vc=12.15, so Vce=0.02v, or ~20mV. The transistor is well-saturated.
Now, for Q2:
Vbe is 670mV, and Vce=3.28. This indicates that the transistor is not saturated.
Yes I follow the current calculationSince Q1's Vc is 12.15v, and Q2's Vbe is 670mV, V(R8)=11.48; R(R8)=3.3k, so Ib(Q2)= 11.48/3300=3.48mA.
(Did you follow that logic? If not, say so.)
I remeasured the voltage across the 1ohm resistor a couple of times. I checked and Q2 is not installed backwards. The voltage measurement from the ecu sensor out wire to the ecu + voltage wire caused smoke and honestly I can't believe I didn't damage the ecu ... I'm guessing the current just went straight through the resistor (I have burned finger tips again even with that monster resistor) and through the wiring to the engine compartment sensor? Before I realized what was going on, it measured -6vDC?This should be plenty to saturate Q2 (low Vce) for a load of 35mA (more than the 30mA you measured), unless perhaps you have Q2 installed incorrectly, or you did not measure the ECU load correctly.
Try measuring the ECU current to ground again using the voltmeter across the 1 Ohm resistor.
Then measure the ECU current to V+ (12v) using the 1 Ohm resistor.
Something is not quite right.
[eta]
I posted the original schematic in .png format. If you wish to edit it and add notes, that's fine - but please do so in .png format, as you went to .jpg format which is "lossy", and is not good for schematic editing.
If you disconnect the ground to the sensor, there WILL be no difference between the two points.
It sounds like you may have fried your ECU when you attempted to use the resistor to measure the current to +12v.
Did you try it on a wrong input, or what happened?
Smoke from the ECU is the last thing you want to see.
You thought that the input was supposed to go from 0v to +12v. Is that what you were seeing before, or is that just what you thought would be the correct input?
Connect a 10k resistor from the base of Q1 to +V.
Connect another 10k resistor from the base of Q2 to GND.
That will help to ensure they are off when they are supposed to be off, and on only when they are supposed to be on.
