As usual, you are correct
I did a test run and my LED stayed on (I have an LED cathode connected to sigout), even when the sigin was generated by the ECU.
The sigin is a PWM signal, but I had previously made a flattener with a 10k resistor and a 1uf capacitor ... that doesn't seem to be working correctly with this new circuit though.
As verification, I brought a 14v (straight from battery/alternator) signal straight to R1 and the LED turned off.
