Looking for hardware component-Image attached
Discussion in 'General Electronics Chat' started by srinivasiyer2308, May 5, 2015.
  1. srinivasiyer2308
    May 5, 2015
    First post here:
    Am looking for a component as in the attached images. It is used for USB testing. One side goes to the system, and the other is connected to the USB device/Device under test. The leads can go to a relay, which can be programmatically used to connect/disconnect the USB device. Not sure internally how the device functions, but have not been able to get any information on this. No one around in my office seems to know as well.
    The text on the component says "USB testing", and a pair of leads labelled "AMPS", another one labelled "VOLTS on one side, and on the other says "IO Systems". The USB end that would go to the system is labelled "IOS"
    Has anyone here seen something like this? If so, any pointers?
    Regards
    Srinivas
  2. srinivasiyer2308
    May 5, 2015
