Looking for full H brigde Chip for control Motor
Discussion in 'General Electronics Chat' started by mpcotuong, Nov 5, 2010.
  1. mpcotuong
    Aug 26, 2010
    170
    Hi All,
    If you know any good H bridge IC chip at least 4A to control 12VDC Motor, please let me know.
    Thanks, in advance.
    Kevin
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    Going past about 2A, H-Bridges are usually used as drivers for discrete Power MOSFETs to do the actual current switching for the bridge.
    One that is rate to 5 Amps is the MC33887
    Heat may be an issue, so this would need a circuit board with a mid-sized copper area to draw heat away from the IC.
    For higher currents one can be used like the Si977DW to drive the actual MOSFET output transistors, Figure 1 toward the bottom of the linked datasheet shows how to do this.
  3. mpcotuong
    Aug 26, 2010
    170
    Thanks, for reply but the MC33887 is end of life.
    Kevin
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  5. mpcotuong
    Aug 26, 2010
    170
    Thanks, for reply but this chip is not available until next year. Do you have any other one?
    Kevin
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It's been in production for a number of years now.
    What do you mean it won't be available until next year?
    Where on earth do you live? You should at least put your Country in your profile. State/province will also help. You don't have to get more specific than that.
    Click on the "User CP" link at the top of the page. Fill in the information in the "Location" box, then click the "Save" button at the bottom.
  7. mpcotuong
    Aug 26, 2010
    170
    I have search at mouser and digikey. They don't have stock for purchase until next January. I am in California
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  9. mpcotuong
    Aug 26, 2010
    170
    Thanks, for your new link.
    Kevin
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I honestly don't know what's going on with those. I haven't looked at authorized distributors stocks for those parts in awhile, but nobody has any except for Farnell in the UK, and they only have 30 or so - of ANY of those parts.
    You're probably going to have to look at using discrete MOSFETs and gate driver ICs, which is going to consume more board space and take longer to assemble.
  11. thatoneguy
    Feb 19, 2009
    6,357
    718
    This site has an MC33887 mounted on PCBoard w/Caps
    Are you looking for something mass production? Otherwise, unsure why "end of life" would matter for a one off hobby circuit, as those parts hang out on the cheaper hobby sites for quite some time.
  12. mpcotuong
    Aug 26, 2010
    170
    Yes, I ink so. I might looking for the Mosfet or replay. Bill has helped me with relay from dual timer 556. I just looking for the H bridge IC, if it available, so that I don't need to build one.
    Thanks, again
    Kevin
  13. mpcotuong
    Aug 26, 2010
    170
    Yes, I am llong for the H bridge IC for mass production
    Thanks,
    Kevin
