looking for coil....anywhhere i can buy?
Discussion in 'General Electronics Chat' started by jamezun, Dec 26, 2005.
  1. jamezun
    Oct 31, 2005
    8
  2. Jimmy Lane
    Dec 27, 2005
    8
    This is what is called a "Choke"....I've also seen it called a toroid. An Inductor.
    Try Radio Shack if you are in the US....otherwise, www.mouser.com should have what you need. Do you know what inductance that you require?
    What are you attempting to do with this....just build an electromagnet?
  3. jamezun
    Oct 31, 2005
    8
    well.. i would like to attach those plate-like coil (should be small enough, around 1cm diameter and 2mm to 3mm thick, with terminal)and allow magnets(similar size) move about it to generate small voltage, however.. I donno where to find them...and its not an inductor... i just dont know what it should be called.. i dun think its a toroid..? a tyroid have no terminal? u get my idea? do u know where can i find those?
    thanks alot~!!!!!
  4. Gorgon
    Aug 14, 2005
    113
    Why don't you wind some yourself, it should be simple enough. Just buy some thin enameled copper wire and wind away on a round tube or something with the diameter you want the coil to be. Put on some glue and pull it of the tube. Remember to scrape of the enamel from the ends of the wire before you solder! If you want the coil to be flat, just put it under something heavy before the glue is completely hard.
    This way you can experiment with all the paramterers involved :D
    TOK ;)
