Looking for cheap daisy-chainable ADC
Discussion in 'Electronics Resources' started by sminded, Jan 15, 2016.
  1. sminded
    Nov 22, 2015
    22
    Does anyone know of a ADC that meets below specs?
    * Daisy-chainable
    * SPI
    * 8 bit
    * >= 100 ks/S
    * 8 channels
    * Single-ended
    * Cost less than $5
  2. JohnInTX
    Jun 26, 2012
    2,391
    1,051
    Not sure what you mean by 'daisy chained' in the multichannel ADC sense, but if you are looking for cheap ADC's that can have multiple units on a bus check out Microchip's offerings. MCP3008 is 10bits, 8 channels, SPI $2.32 Qty 1 from Mouser or Microchip Direct. These are successive approx. SPI units. uCHIP has other types/resolutions/channels.
    Many other manufacturers like Maxim, Analog Devices and TI come to mind as well. I am the most familiar with Microchip for average to good stuff and Analog Devices for their high end stuff. Although Max and TI are good outfits too, I just don't know their products lines as well.
    Good luck in your search.
    sminded likes this.
  3. sminded
    Nov 22, 2015
    22
    I need to connect a bunch of adc:s together and send config through to all of them through the first adc in the chain and recieve data from all of them through the last adc in the chain.
    Basically i would first send the config data through SPI DIN which will propogate to all adc:s through DIN and DOUT being connected between them, then i will let the adc:s sample and hold, then i will start the conversion in parallell on all adc:s, so when one adc clocks out the first bit on DOUT it will receive its neighbours first bit on DIN and so on...
    Some adc:s do have this feature, TI call it daisy-chainable oscillator, but im trying to figure out if it might only be in the high end parts.
    Reason i need it is because im doing a serially connected modular board. Previously I was using shiftregisters 74165 which was working fine for "binary" sensors but now i need to collect a bunch of analog values (256 to be exact).
  4. JohnInTX
    Jun 26, 2012
    2,391
    1,051
    Ah... I see. You have 256 bits of digital info reduced to SPI by daisy chaining 32 74165, you latch them in parallel then shift in the 256 bits of digital data, yes?
    And now, each of those 256 digital channels is going to be the 8 bit ADC result for a total of 2048 bits of data shifted in the same way - presumably to be compatible with existing hardware, yes?
    A couple more questions, you mentioned 8 channel ADC's. Any inexpensive one of those will only convert one channel at a time. If you are proposing to convert all 256 channels in parallel at once, I'm thinking you need 256 chips, daisy chained or not, unless you find some special purpose gizmo.
    How are you at micro-controllers? PICs with ADC's are way cheap. You could buy one per channel, write some bit-banged shift code for the results and trigger all the start-of-conversions with a single line connected to an interrupt. Even the cheap ones have single/differential inputs with built in precision references. If you can live with 1 of 8 channels per conversion time, you can get one with more analog channels. If one of those ideas floats your boat, I can pick a good one for you. With some smarts on board you can also do some signal conditioning before sending the data.
    How fast is the SPI clock?
    Interesting!
    EDIT: Here are a couple of PICs to look at if the microcontroller route strikes your fancy
    8 pins 1 channel $0.36/5K 10F320/2
    14 pins 8 channels $0.53/5K 16F1503 et al
    Both have 10bit ADCs (can use 8MSbits) and internal reference.
    sminded likes this.
  5. sminded
    Nov 22, 2015
    22
    Exactly, .. the board is a 4x4 cell ledboard, where each cell is having a touch sensor (and a rgb led), so the input to the adc is from a photoresistor 0-5V.
    No, its enough to have one channel at a time. So the idea would be to have two 8-channel adc:s per board covering all 16 inputs or if they are expensive only one and then some kind of mux to select between the first 8 inputs and second 8 inputs.
    As long as I can poll all 256 inputs within 100ms its good enough for touch sensing, but within 10ms would feel more comfortable :)
    I like the idea.. are you suggesting that I can make it act as a SPI slave and daisy chain the PICs? Sounds really interesting as it will be very flexible and like you say I can offload the microcontroller. Come to think of it I could actually put a lot of smartness on the PIC as I need to define trigger levels and do calibrations per phototransistor etc. So the PIC could probably send a descreet 1 or 0 to the controller and keep the analog value to itself.
    Really nice, the 8 channel could work, I will read up on it... thanks
  6. joeyd999
    Jun 6, 2011
    2,756
    2,914
    And, if you are *really* clever, you'll program each with "boot" code that will allow reprogramming each MCU via the same serial wire.
    sminded likes this.
  7. sminded
    Nov 22, 2015
    22
    I will definitely do that :p
  8. sminded
    Nov 22, 2015
    22
  9. JohnInTX
    Jun 26, 2012
    2,391
    1,051
    @sminded I would not recommend the '527 or any of the midrange PICs when the Enhanced Midrange is available (16F1xxx). They are much more up to date, have many more resources and don't suffer from r-m-w I/O problems (which could easily become an issue driving SPI wires) and have the sparkling -ME2 debugger available.
    PICkit3 should work - I'll check the DTS and verify that and give you some links to the debugger. If you are thinking about a bootloader, you'll appreciate the 16F1xxx a lot.
    I just did a couple of projects with this setup:
    16F1825 - Max memory for development, you can downshift later if everything fits. Note that its internal oscillator can run at 32MHz vs 8 for the '527. If you are going to bitbang SPI, you'll appreciate that.
    PICkit3 - The basic programmer/debugger. I use RealICE but PK3 is certainly serviceable and considerably cheaper. It provides basic debugging using the chip's resources. Using PK3 by itself will consume the ICSP pins for debugging and be limited to the on-chip resources (limited breakpoints etc. See MPLABX Help Files for particulars)
    AC244043 - Debug header. This recovers the pins used by ICSP but doesn't add much else. Some of these recover the chip's memory used by the on-chip debugger. But for the small price difference get:
    AC244063 -ME2 Emulation Extension Pack instead.
    This is close to a full-blown emulator - I use the -ME2 and its great. Check the features list.
    That's what I would do.
    Would you use C or assembler?
    sminded likes this.
  10. sminded
    Nov 22, 2015
    22
    Ok, I hear you, and agree 16F1 it is.
    Ok, nice idea, they seem to be pin compatible and all. Have I understood correctly that I can use 8 analog pins, and 4 other pins for SPI, and two of those SPI pins can handle interrupts?
    So RA0--RA2 + RA4 + RC0--RC3 will be my analog pins and I can use RA3 + RA5 with SPI and interrupts and also RC5--RC6 aswell for SPI.
    I guess the SPI-function in the PIC is only for Master SPI, so I'll be implementing some kind of statemachine thing driven by interrupt on the CS and CLK pins. For example CS (RA3) high will reset the statemachine and CS low will initialize it. And then the CLK (RA5) signal will be on interrupt so I can read and write data on DOUT correctly. Can I have four interrupts, two for falling and rising edge on CS and two for falling/rising edge on CLK?
    My idea would be to have the first byte send out from the master to the PICS after a CS falling edge to be configuration + command. So with this byte I can tell the PIC to calibrate channel 1 (RA0) or read from channel 1 (first 4 bits could be the command and last 4 could be channel number). I could also send threshold values this way.
    You asked about the clock speed of the SPI before, it will be fine tuned obviously, but I will aim for something like 2-8 Mhz. If I don't need to send the full analog value through SPI per channel, but only ON/OFF bit then I can keep the Mhz down to 2 Mhz perhaps.
    The only down side to using the PIC as compared to a real ADC is that with the real ADC I could send the data as the conversion is going on bit by bit, but with the PIC I guess I have to sample and hold the whole board and then go into SPI transfer. No big issue but it decreases the throughput somewhat.
    Ok, great, I will try to make it so that I can program one board 4x4 cells, two PICS, or if possible the whole table (16 boards +) using one programming header on the board, using bootloader and ICSP.
    I will definitely use C, so which compiler would be the best?
  11. JohnInTX
    Jun 26, 2012
    2,391
    1,051
    Sorry for late reply and style, on a little tablet.. I would start with XC8 and MPLABX from uCHIP. Xc8 does a decent job in free mode - check price for PRO version. You can develop in free mode and try a one time upgrade to PRO that lasts 30? Days. I have roughed out some intermals for you and will post when back in office - I had to convince myself it would work. It will. Grab the datasheet and rough out a pinout starting with the analog chamels (look at ADCconfig stuff for pin availability) then do the SPI link. If this has to plug into an extisting system, hook this up the same then post the sketch and the serial info so we can kick around how to use the interupts etc. to best advantage.Fun!
    sminded likes this.
  12. sminded
    Nov 22, 2015
    22
    Hi John, thanks for all the help, I have ordered the parts from china, i.e PIC:s and programmer and some soic to DIP adapters. I will update my schematics with the two PIC:s asap.
  13. JohnInTX
    Jun 26, 2012
    2,391
    1,051
    @sminded
    Hmmm.. I wish I had known that. Hopefully by 'China' you mean from uCHIP direct in China (a lot comes from their ops in Taiwan) but I don't recommend any of the third party stuff nor any purchase of parts from China. Many problems posted here revolve around 3rd party stuff and counterfeit parts from China. If you can bail on that, I would and get them from uCHIP or a franchised distributor.
  14. sminded
    Nov 22, 2015
    22
    I understand the general problem with China parts, however, I regularly buy things from China, and it has always worked so far without any problems. When I bye from US I always get slammed with VAT and import fees from the swedish agencys so I end up paying double price at least as compared to China. I only bought 6 pieces for a few $, and there is a good chance it can be original parts (as stated in the ad from the seller).
    I checked out the uchip store, but there you need to bye at least a tube.
    EDIT: I cancelled the China order, and got the parts from Digikey UK store :p
  15. sminded
    Nov 22, 2015
    22
    Ok, here is the schematic part with touch sensors and PIC MCU:s acting as SPI-enabled daisy-chained ADC:s.
    Imagine many 4x4 boards being daisy-chained with angled male/female IDC-headers connecting the boards.
    The board will have incoming headers on left and top side and outgoing headers on right and bottom side.
    With jumpers it will be possible to decide if the inputs will come from top or left side.
    Using this way you can build up a bigger rectangular board using for example 16 4x4 boards, where all the data signals will be daisy chained, so the initial signals from the controller (Teensy 3.1) will be connected using a flat cable to the first board and ripple through to the last board, and from the last board, the output header/signals will be connected back to the controller board using another flat cable.
    All boards, including the controller board will be individually powered from a single 10A 5V DC adapter using a 2-pin screw terminal on each board.
    Explanation of signals:
    IR_EN: enables the four 800mA transistors which powers the IR leds. Will be set at the start of a sample and reset after the ADC:s have done the sample and hold.
    IR1--IR16: This is the output from the phototransistor 0-5V, proportional to the touch distance and will be connected to the PIC:s
    IR_CKI: SPI clock line for the PICs
    IR_LD: Resets all the PICs and makes them ready for a new command
    IR_SDI: This is the serial data in for this board, can come from either the controller or a previous board
    IR_SDO> This is the serial data out, can be connected to the next board, or if this is the last board in the chain, the teensy controller
    The good thing with this solution is that I can let the PICs do the ADC stuff and send out one bit per channel ON/OFF. The pixel/cell will be regarded as ON when the voltage on the corresponding channel reaches the treshold value for this particular cell.
    The treshold can be individually calibrated from the Teensy by sending a calibration command with a channel number to a specific PIC in the chain, and just a NOOP command to the rest of the PICs. The user will touch the specific cell to be calibrated and that value will be used.
    Perhaps two values will be stored per cell at each calibration, the untouched value and the touched value. Then (if needed) continously or at startup the controller can order all the PIC:s to register the idle value (not touched) of each channel,
  16. JohnInTX
    Jun 26, 2012
    2,391
    1,051
    Sorry again for the delay - moderator duties are consuming a lot of time these days..
    Anyway, thanks for the skiz and description. The way you have the serial is more like a daisy chained shift registers than SPI (but you did say you were replacing 74165's) so yeah! That should do the trick. You've done a good job of assigning pins (clock and load on interrupt-on-change, nice) and you'll be bit banging the serial link. My original sketch daisy chained the MSSP/SPI to avoid big banging but I see that you've matched the new circuit to your old one..
    I assumed that you were going to send 8*8bit ADC readings and had a nice little data stack cooked up but having the ADC value simply compared to a threshold makes it easier yet. Very cool.
    I don't know if you've figured out how to organize the code but here's how I probably would approach it:
    Run the internal oscillator as fast as it will go.
    Run the ADC by converting each channel in a continuous round robin sequence. When one conversion is done, read the data and change the ADC channel and start the conversion on that channel. Next, process the data (average a few values if you need to then compare to the reference value. Post the result bit in a holding register (ADC_RESULTS). Just keep doing this as often as you can. The holding register will always contain the latest result of the conversion process.
    When the LATCH signal happens, the interrupt immediately copies ADC_RESULTS to the shift register (that way new ADC results can be posted without clobbering the shift process).
    As you shift each bit out, shift one in to a separate receive register, keeping a bit count. When the count is 8, transfer the receive register to the transmit register and continue. The 8 bit values from each PIC will be propagated along the line as long as the clock is going.
    Restart the process for each latch pulse - copy the updated ADC_RESULTS to the shift register and shift as many bytes as you get clocks.
    This approach works for any number of PICs on the chain - just hit the latch pulse and send 8x clocks. The PICs don't know the difference.
    As the new ADC_RESULT data is shifted out, you shift in any command data you need byte by byte. The command bytes wind up aligned in the receive registers and are examined after the last data shift. You'll need a way to know when that is and what the commands are. That may in fact require knowing how many PICs are on the chain (after all bytes shifted out, what's in the receive register is a command). Alternatively, you might be able to come up with a method of using the latch and clock signals to indicate whether a command follows the data shift i.e. latch with the clock = 1: no command follows the data shift operation; latch with the clock=0, command follows.. something like that.
    I would keep the ADC scheduler as a non-interrupt routine so that you can respond to the clock and keep your speed up. Just run the ADC as the main task whose job it is to post bits into the ADC_RESULTS register. If getting a shift clock happens while you are changing channels, it doesn't matter because you already loaded the shift register with the ADC_RESULTS.
    See if you can do the latch/shift without a state machine - again for speed.
    The 16F1xxx have very quick interrupt response because all of the important registers are saved automatically in hardware - faster even than the 18F's and WAY better than that lame '527.
    I can see it working already.
    Nice job!
  17. sminded
    Nov 22, 2015
    22
    Thanks again for the input.
    Yea, true, I have just replaced the shift registers with these PICs, but how can I avoid bit banging? I have no problem adapting the schematics if I can find a better solution.
    I was thinking that I probably don't need to know the full value range 0-4096 or whatever I will get from the ADC:s in the Teensy controller, as I'm not planning to have any application that will behave upon touch distance. The games/features I forsee will only need to know if a cell/pixel have been touched or not.
    And obviously the less data I need to shift in each sample, the better ;)
    Wow.. thanks for the insights.. I will again look at this when its time for the programming of the PIC:s
    JohnInTX likes this.
  18. JohnInTX
    Jun 26, 2012
    2,391
    1,051
    At this point, I think you'd have to go to the '1829. It has more pins and more importantly, using the hardware SPI doesn't eat up the analog channels that you need. Tables 1 and 2 in the datasheet tell the tale. For the 1825, SDI shares RC1 with AN5 and its not relocatable. That means no hardware SPI or no 8 channels of ADC leaving you with bit banging. I thought about it and don't see why you could not daisy chain the hardware SPI if you had it. Probably the thing to do at this point is take the hardware you have and get the data link working. If you can use the 1829 in your final design, I'd try the data link with the hardware SPI with dummy ADC data for now. If it works OK, order some 1829s and start the ADC code. If you must use the 1825, then you'll be bit banging and just have to keep the code tight as possible. This would probably be a good time as well to see how much data rate you actually need vs. what you originally indicated.
    Agreed. The key is to design the basic code structure so that if you want to get analog values someday, you don't have to start from scratch.
    You're welcome. Its fun to think about stuff like this.
