Wrong. All semiconductor devices can be damaged by electrostatic discharge.BJTs and diodes are not at risk of damage.
If you're quoting a textbook then I agree. But in reality? I've never had one go on me. I usually place all CMOS parts on conductive foam or in tubes, but TTL etc .. I just throw them in my parts containers. Never had a problem in all my years.Wrong. All semiconductor devices can be damaged by electrostatic discharge.
I have. 2N2222A, CMOS, you name it, and it was at a place that had static controls in place.If you're quoting a textbook then I agree. But in reality? I've never had one go on me. I usually place all CMOS parts on conductive foam or in tubes, but TTL etc .. I just throw them in my parts containers. Never had a problem in all my years.
I am not quoting from a textbook.If you're quoting a textbook then I agree. But in reality? I've never had one go on me. I usually place all CMOS parts on conductive foam or in tubes
You are DEAD WRONG. This may be the case for a hobbyist.but TTL etc .. I just throw them in my parts containers. Never had a problem in all my years.
You may have never had one completely fail, but you most likely have inadvertently affected the noise floor, gain, max breakdown voltage current, and other parameters that aren't readily apparent.I have been reasonably happy with my dealings with Element 14 (formally Farnel Components)
Prices are good for semiconductors. They are negotiable as well. They follow strict anti-static protocols too. Sometimes a bit too over the top. BJTs and diodes are not at risk of damage.
Most popular general purpose transistor ever developed?I have. 2N2222A
Knowing my luck most probably. Now I know why some of those circuits that I created made sense on paper but didn't quite cut it on the real world build.You may have never had one completely fail, but you most likely have inadvertently affected the noise floor, gain, max breakdown voltage current, and other parameters that aren't readily apparent.
by Aaron Carman
by Aaron Carman
by Aaron Carman
by Duane Benson
