I have an older 500 watt subwoofer plate amp that quit working and I was wondering if there was someone here willing to help guide me through diagnosing the problem. I have some electronics experience from college but it has been several years since I've utilized anything I learned. Use it or loose it I guess.
Anyway, the subwoofer that the plate amp was in sat around for several years before I decided to hook it up one day. I used the line level inputs and it seemed to be working fine for several hours and then quit. I took the plate amp out of the enclosure and found two resistors coming from the line level inputs totally fried to the point I couldn't make out their values. They both measured nearly 100 ohm so I replaced them with new ones but there is still an issue. Unfortunately, the amplifier still doesn't produce any output.
I have an old Tektronix 465 analog scope and multimeter but am not knowledgeable enough to know what kind of voltages I should be seeing without a schematic. I am also having a hard time following the signal path so when "poking around" with the scope I tend to get lost.
I am eager to learn more about electronics repair, specifically for audio applications but really could use some guidance.
If I were to provide pictures of the amp could someone help identify what I am looking at and what I should be seeing with my test equipment?
Any help or advice would be greatly appreciated.
